Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Design Rule Verification
  • Locked Locked
  • Replies 9 replies
  • Subscribers 90 subscribers
  • Views 1436 views
dmitriy2020
dmitriy2020 over 6 years ago
Hello.
I make multilayer PCB with blind and buried vias. I have a problem with rule verification.
The rules was made for each layers separately . That way is convenient for my design.
for example 0.1mm:
There are blind via (TOP- Signal layer 1) and buried via (Signal layer 1- Signal layer 6 ).  Both of vias are on the Signal layer 1 with distance 0.06mm.
1 Checking design rules does not give any errors though the gap is only 0.06mm on Signal layer 1.
2 If I use a general rule for all leyers  I will get the correct сlearance  constraint error.
Why the rule does not work in the first case? Could you help me with rules for separate layers.
  • voltsandjolts
    voltsandjolts over 6 years ago in reply to dmitriy2020 +1
    I think there might be a bug. To me, it looks like if you have a clearance rule specifying layer (e.g. Top Layer - ALL) then: Track to track is checked OK Track to via is checked OK Via to Via is NOT checked…
  • voltsandjolts
    Try this:
  • voltsandjolts
    You can add net classes to get different clearances as required.
    You can use the net class directive on the schematic or, if you need lots of those, it's easier to use net blankets:
    https://www.eevblog.com/forum/circuit-studio/net-blankets-for-circuitstudio/
  • dmitriy2020
    dmitriy2020 over 6 years ago in reply to voltsandjolts
    This way (OnLayer('Signal Layer 1') -  InNetClass('All Nets')  Clearance = 0.1mm )  doesn't work too. It look like a bug of CircuitStudio . Can you confirm that the case is repeated on your computer?
  • voltsandjolts
    Can you provide a simple CsPcbDoc here that shows the problem, thanks.
    Check online DRC is enabled;
    File > System Preferences > PCB Editor > General > Online DRC
  • dmitriy2020
    There is online DRC. I tried several variants :
    still not getting any error
    Please check CsPcbDoc :
    new_pcb_test.zip
  • voltsandjolts
    Edit:
    Ah, its not a bug, it needs another rule.
    Vias (and TH-pads) are "Multi-Layer" objects so a rule like [Top Layer - ALL] does not apply to them. They are not on the "Top Layer" ... not intuitive logic I would say, but thats the way it is.
    Create an additional rule for via/pad clearance to other vias/pads.
    (Enter -1 for Minimum Clearance then enter clearance values)
  • dmitriy2020
    It is worth noting  Your rule is not for signal layer 1. No doubt, general rules are work well.
    I think the bug appears for blind and buried vias on selected layers only. The rule is not checked between rings of vias .
  • voltsandjolts
    Correct, the above rule and clearance apply to all layers.
    So, you would need to use worst case clearance value for all layers.
    I can't see a way to to specify via-to-via clearance differently for each layer.
    Please post here if you find a way.
    Are you saying the rule I posted above is not applied to blind and buried vias?
  • dmitriy2020
    Thanks for the help. I will follow your recommendations.
