Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Circuit studio features
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 544 views
  • frontpage
satya247
satya247 over 9 years ago
Hi All
I am new to circuit Studio.
I want to know weather Circuit studio supports RF and microwave designs ?
Does it have any tools related to Microwave design ?
Can do 50 ohm (45, 90 degree) bends ?
Many thanks
Regards
Satya
  • e14softwareteam
    0 e14softwareteam over 9 years ago
    Will check with the developers.
    e14 Software Team
  • e14softwareteam
    From the developers:
    CircuitStudio does not directly create RF structures. One technique is to import a DXF file containing the shapes created in an external program, onto a layer such as TopLayer. This will create tracks on the PCB. Then use the command Home > Solid Region to manually trace over the tracks by snapping to each vertices when the circle appears to indicate the cursor is over the vertices. Once you've traced around the shape, right click twice to complete the Solid Region. Then remove the tracks. The SolidRegion is then a piece of copper that forms the required bend.
    e14 Software Team
