Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Library Part Ref Des/Part Number Font
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 668 views
spe672
spe672 over 9 years ago
Where is the parameter adjustment for the Ref Des in the Schematic Symbol Library?  When I make a part from scratch, the Ref Des is usually Times New Roman, 10.  I pulled in a part from SnapEDA and the Ref Des is Arial, 14.  I can edit the text once it is in the schematic; I want to update it at the source in the library, not every time I place a part.
The one on the left needs the font tweaked and "Autoposition" checked to allow me to move the text around.
Problem is, I can't access these parameters in the Library area...
The Edit button affects text in the Paramters, but not the Properties such as Default Designator.  The editor is squashing my picture...look in the Library Component Properties area to see the picture above.
Ideas?? Thanks!
  • e14softwareteam
    0 e14softwareteam over 9 years ago
    Checking with the developers.
  • e14softwareuk
    0 e14softwareuk over 9 years ago
    There is a way to change the default Ref Des font of a schematic library symbol.
    Bring up the Library Editor Workspace dialog (Tools > Document Options) and check Always Show Comment/Designator.
    When editing a symbol you can select the Ref Des text and use View > Inspector to change the font.
