Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum NC Drill files and ODB++ files
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 2499 views
  • frontpage
satyaeee247
satyaeee247 over 9 years ago
Hi Guys,
I am having trouble with NC drill files which I can't open in any Gerber viewer
and ODB++ are also giving me error while I am trying to open those files in ODB++ viewer 9.8 from Mentor Graphics.
Is there anything in the settings i am doing wrong or someone else have the same issue?
MAny thanks
Satya
  • satyaeee247
    0 satyaeee247 over 9 years ago
    I tried to generate NC drill files using one of the reference design even this giving me same problem.
  • harvie256
    0 harvie256 over 9 years ago
    I don't know about ODB++ files as I don't use them.  However with NC drill files it all comes down to exporting them in a format that your reader can accept.
    I read them with gerbv and I've found exporting in mm to 4 decimal places, keeping leading and trailing zeros and the relative origin works fine.  Also I've never had a complaint from the many PCB houses I've used in China.
    So perhaps try those settings?
  • satyaeee247
    0 satyaeee247 over 9 years ago in reply to harvie256
    Hi Harvie,
    Thanks for your reply.
    I tried the configuration you described still cant read the file
    I used Gerbv software to read, same problem can't read
    May I know  where I am doing wrong.
    Many thanks
    Satya
  • harvie256
    0 harvie256 over 9 years ago in reply to satyaeee247
    Looks like you're opening the wrong file.
    The DRL file is a EIA binary drill file (which I have no idea what reads that), it's not the text based Numerical Control drill file.
    The NC drill file will have a .txt extension and can be opened in a text editor.  It's just G-Code to drill a bunch of holes, nothing special. It will look something like:
    M48
    ;Layer_Color=6321
    ;FILE_FORMAT=4:4
    METRIC
    ;TYPE=PLATED
    T1F00S00C0.9000
    T2F00S00C1.5000
    T3F00S00C2.2000
    ;TYPE=NON_PLATED
    T4F00S00C3.0000
    T01
    X01566840Y00440360
    X01690240
    X01715640
    X01741040
    X01766440
