Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum PDF Schematic Output job
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1211 views
  • frontpage
jimku
jimku over 9 years ago
In CircuitStudio, I am trying to setup my schematic page output job (Project - Generate Outputs - Documentation - Schematic - page setup) to Leger(11x17) but this is not a selection. This is a common size to output schematics since most office printers have this size and its twice the size of letter size (8.5x11). I can directly print to this size using the Print documentation but would like to generate a pdf using the output job. Am I missing something in a setup somewhere?
  • tarribred61
    tarribred61 over 9 years ago +1 verified
    Do you mean tabloid size? For the above I had my printer set to Microsoft Print to PDF as the driver. This is set through the Outputs > Print. Just in case it is the driver selection that you have.
  • tarribred61
    0 tarribred61 over 9 years ago
  • jimku
    0 jimku over 9 years ago in reply to tarribred61
    Yes, tabloid size. The second part of your answer may be the clue to getting it to output the tabloid size. I do not have "Microsoft to PDF" printer selection available. I did a web search on why and found that I need to install the driver but still cannot find the driver to install. I have windows 7 and somewhere I read that the Microsoft pdf driver is only supplied in windows 10. I may need to find a different PDF driver to install and see if that will work. It's strange in that I do not have a PDF driver selected but I am able to output a "letter" size pdf but not a "tabloid" size. Thanks for your answer. I think that I will be able to find a pdf driver and hopefully that will work.
  • tarribred61
    0 tarribred61 over 9 years ago in reply to jimku
    FWIW, try Foxit PDF reader/editor.  It has a limited free version that works for me.  I think it works in Win7. You can find it with reviews on CNET.
    Foxit Reader - Free download and software reviews - CNET Download.com
