Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Groups in Circuit Studio
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1571 views
  • frontpage
mrne
mrne over 9 years ago
Hello, is the circuit stuido the possibility of creating groups of components when designing a PCB that holds the position towards each other? If not, is this feature going to be implemented in future releases?
  • e14softwareuk
    0 e14softwareuk over 9 years ago
    Hi David, I don't believe that is possible. The nearest is probably locking the components so they cannot be accidentally moved. At this time there is no published information features in upcoming releases.,
  • tarribred61
    0 tarribred61 over 9 years ago
    In CS it is not as easy to do as in full Altium Designer.  In Altium the terminology is a union.  In Altium it is possible use the mouse to drag a window about a group of parts in the PCB layout and create a union of the parts that is then locked together.
    However, you can use cross-probe functions to select parts on the schematic and then move them together on the PCB.  It probably won't move routed tracks though and it isn't as functional as unions.  This is probably one of the features that intentionally differentiate the CAD packages.  If this is enough of a productivity issue then you can pay for the upgrade to full Altium and get this along with better polygon management, 3D placement of designators, layer sets, flex circuit support, etc..
