Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Error Reporting
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 707 views
  • frontpage
  • error report
  • Tech Support
Error Reporting
yadhu22krish@gmail.com
yadhu22krish@gmail.com over 9 years ago
It seems that we need to edit the error reporting a like the design rules for each project.There is a default option but it contains errors like "Nets with Only Pin as NO REPORT.."...As far as I am concerned this should be fatal error.Please consider that.Is there any way that we can edit the defaults error reporting rules and saves it. So we dont need to edit them for each project.
  • e14softwareuk
    0 e14softwareuk over 9 years ago
    It may be best to create a new project to act as a template. Set up the desired rules and then copy the project when you need to start a new design.
  • yadhu22krish@gmail.com
    0 yadhu22krish@gmail.com over 9 years ago
    I started to do like that. I think this is the only solution.image
