Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Schematic PDF generation
  • Locked Locked
  • Subscribers 91 subscribers
  • Views 2491 views
  • frontpage
yadhu22krish@gmail.com
yadhu22krish@gmail.com over 9 years ago
When I try to generate a schematic PDF, Each page appears two times. Why is it so ? What am i doing wrong ?
  • adamwebber
    adamwebber over 9 years ago +1 verified
    This is sort of a problem with CircuitStudio. You probably are using a copy of your original program where you changed the filenames of the project and project documents. So now your *.outjob file doesn…
  • e14softwareuk
    0 e14softwareuk over 9 years ago
    Hi. Is this when you print or preview? Which print menu are you using, Project > Generate Outputs or Outputs > Print? Does you design have any repeated design blocks / sheets?
  • adamwebber
    0 adamwebber over 9 years ago
    This is sort of a problem with CircuitStudio.  You probably are using a copy of your original program where you changed the filenames of the project and project documents.  So now your *.outjob file doesn't match up with the filenames anymore.  When you generate your outputs, it looks for the filenames and folder structure but can't find them because they don't match up.  So it generates a whole new set of outputs.  Open your *.outjob file using a text editor and delete the duplicates.  You'll see that it has 15 or so individual settings and then duplicates of them all.  Just look at the first setting.  Should be BOM.  Then scroll down until you find the second instance of BOM.  Delete everything up to the last number.  There is a space at the end followed by some other settings.  Stop at the space.
  • alexsander_altium
    0 alexsander_altium over 9 years ago in reply to adamwebber
    Nice post as usual James. Hopefully this solves the problem.
  • yadhu22krish@gmail.com
    0 yadhu22krish@gmail.com over 9 years ago in reply to e14softwareuk
    Hi Peter,
    I didnt try to print. I tried to Generate schematic prints from generate outputs. I have 10 sheets, but after PDF generation it becomes 20 sheets. Each page generates two times. I didn't understood what you meant by repeated blocks. I dont have any repeated sheets in my design.
    0 yadhu22krish@gmail.com over 9 years ago in reply to adamwebber
    Hi James,
    I tried your tip and it worked. Thanks for the info. I couldn't understood the logic behind this. image
