Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Hanging for a long time.
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 891 views
  • frontpage
yadhu22krish@gmail.com
yadhu22krish@gmail.com over 9 years ago
hi,.
Whenever I touch a polygon which means,whether to repour or delete or even to select the circuit studio will hang for a huge time period. Why is it so  ?
  • e14softwareuk
    0 e14softwareuk over 9 years ago
    I have previously encountered one support instance where this was happening, the program would pause for a minute or two after touching a polygon. Hopefully the workaround will be applicable to you. If your polygon is filled then try changing to hatched, if you make the grid the same as the line width the hatching will create a solid area and hopefully there will be no delays.
  • sparker_1
    0 sparker_1 over 9 years ago in reply to e14softwareuk
    I have this problem too!
    The work around you (Peter) suggested works well. Just need to note that the polygon is expanding outside the drawn area by half the track width.
  • yadhu22krish@gmail.com
    0 yadhu22krish@gmail.com over 8 years ago
    Problem is solved.
    Check my comment on this link. It works fine for me in this way.
    https://www.element14.com/community/message/227986/l/issues-with-polygon#227986
