Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Multiple output sheet entrys error on multichannel design with REPEAT keyword
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 2517 views
  • frontpage
ferranm
ferranm over 8 years ago
I'm getting a "Multiple output sheet entrys error" when working on the following multichannel design in the "ESD.SchDoc" and "SALIDAS.SchDoc" module.
I have followed the guidelines on Multi-Sheet and Multi-Channel Design | Online Documentation for Altium Products
Input ports seem to work ok, but output ports raise the error.
At the bottom there is also a multichannel configuration without the REPEAT keyword on "INTENSIDAD.SchDoc" sheet that seems to work,
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    Does using Repeat(INF) instead of INF to label the sheet entry work?
  • ferranm
    0 ferranm over 8 years ago in reply to e14softwareuk
    Yes. That solved the problem.
    Thank you very much.
