Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Multiple connectors one module?
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 817 views
  • frontpage
Marl_Evans
Marl_Evans over 8 years ago
I have an Iridium module that has multiple connectors on it that all require footprints on the PCB.  I would like to create a component that will give each connector a unique designator and pick and place location.  How best to do this?
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    If you are looking for each connector to have its own unique location and designator it sounds like you would need to design an PCB and then have the connectors as components on that PCB.
  • tarribred61
    0 tarribred61 over 8 years ago
    I have done this before as individual connectors on the PCB and not combined them into one part.  If you plan to use this often in the future then you could also build a placement aid as a mechanical part only (no BOM) that has the placement guides on mechanical layers.  Then you can align the individual connectors easily.  You can further verify placement in 3D mode if you have a step model of the Iridium module.  This is where the 3D capability of CS is very useful.
  • Marl_Evans
    0 Marl_Evans over 8 years ago in reply to tarribred61
    Thank you for your answer.  It is as I thought.
