Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Global nets
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1006 views
  • frontpage
Global nets
chwast
chwast over 8 years ago
I am designing the multi-page schematic and I would like to pass some signals from one page to another ( the same with the the supply nets and GND ). When I tried to generate the the output I get the warnings. Could you help me to understand how to solve those warnings.
Page2
Page3
Warning message
Thanks a lot in advnace
Jacek Pieczaba
  • csiemer
    0 csiemer over 8 years ago
    This violation occurs when a net in the design has been detected to have no driving source. That is, the net does not include at least one pin with one of the following electrical types:
    • IO
    • Output
    • Open Collector
    • HiZ
    • Emitter
    • Power
    Pin type definitions are generally done in the library, but can be modified on the Schematic.
    This is also a fairly common warning to receive if you use passive pins a lot in your design.  Not necessarily something you need to worry about unless you are being meticulous about pin type definitions.
  • chwast
    0 chwast over 8 years ago in reply to csiemer
    Thank you very much
    Jacek
