Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Gerber file import?
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1369 views
  • frontpage
  • gerber import
Gerber file import?
chuckbluz
chuckbluz over 8 years ago
I have a number of Gerber files that I need to import into CS so that I can modify the designs. Can I do this?
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    Do you have any alternative data other than Gerber because CS does not include a Gerber import function.
  • frog
    0 frog over 8 years ago
    Although you can't import Gerbers directly, you could convert to an image format (e.g. PNG) although CS can only import bitmaps and not vector formats, so the rendering won't be perfect.  Furthermore, gerber just gives you an image of the tracks and doesn't provide any information about the schematic and netlist; unless the changes are trivial it will be a struggle.  Alternatively, Gerber files are human-readable (kind of) and so if the changes are minor then the simplest solution might be to edit the Gerbers with a text editor and then check them with a Gerber viewer (e.g. Gerbv).  If the changes are more complex then it's likely to be quicker to start from scratch with a schematic.
  • chuckbluz
    0 chuckbluz over 8 years ago in reply to e14softwareuk
    Nope, Gerber is all I have for these boards.
