Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Cannot locate document
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 8724 views
  • frontpage
  • circuitstudio
misixse
misixse over 8 years ago
I'm new to Circuitstudio, although I have used Circuitmaker a lot.
I'm trying out the most basic steps:
Create a new PCB (project)
Add a schematic
Add a PCB
Place one component on the schematic
Update the PCB
Boom, I get a "Cannot locate document[PCB1.CSPcbDoc]
There are no hints as to what could be wrong.
I have searched forum, but nothing found.
  • jimku
    jimku over 8 years ago +1 verified
    Be sure to compile the schematic and save both the schematic and pcb file, then update the PCB. I don't remember but you may need to save the PCB1.CSPcbDoc as something other than the default file name…
  • jimku
    0 jimku over 8 years ago
    Be sure to compile the schematic and save both the schematic and pcb file, then update the PCB. I don't remember but you may need to save the PCB1.CSPcbDoc as something other than the default file name.
  • jpnbino
    0 jpnbino over 8 years ago in reply to jimku
    Also,
    Use an example project provide to check extensions
  • misixse
    0 misixse over 8 years ago in reply to jimku
    Thanks! This did the trick.
