Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Can I import my CM project to CS?
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 959 views
  • frontpage
yassirreebob
yassirreebob over 7 years ago
I would like to upgrade from Circuitmaker to Circuitstudio. Can I import my CM project to CS?
Chuck Schall
cwschall@optimum.net
  • e14softwareuk
    e14softwareuk over 7 years ago in reply to yassirreebob +1
    You need to use the File > Import command rather than open the PCB directly.
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    I believe both CS and CM use the same schematic document file format (*.SchDoc) and CS includes an importer for CM PCBs (*.CMPcbDoc) so you should be able to import your projects.
  • yassirreebob
    0 yassirreebob over 7 years ago in reply to e14softwareuk
    Hi Peter,
    Thank you for your response.
    When I open my CM .prjpcb project in CS, the .schdoc opens correctly as a "source" document, but the .cmppcbdoc opens as an "other" document and I cannot open it.
    I cannot find a CM importer within CS.
    Best regards,
    Chuck Schall
  • e14softwareuk
    0 e14softwareuk over 7 years ago in reply to yassirreebob
  • yassirreebob
    Many thanks, Peter. That did the trick.
    Best regards
