Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum changing layer/properties of entire trace
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 947 views
  • frontpage
Sparkylabs
Sparkylabs over 7 years ago
How do I change the properties of an entire trace rather than segment at a time?
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    Use Home | Select > Physical Connection to select all the segments and then use View | Object Inspector to adjust the track width of all segments connecting two points. To change a net globally first set the Tracks filter, use Select > Connected Copper and then just as before adjust the width using the object inspector.
  • Sparkylabs
    0 Sparkylabs over 7 years ago in reply to e14softwareuk
    that works but on my last instance of doing this the two tracks that i need to move in order stop a collision cannot be moved, i will have to remove them and start again. Just another one of the usual BUGS that Farnell and Altium will pretend don't exist......
