Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Synchronize Schematic with Updated Library Part
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1762 views
larry_137
larry_137 over 7 years ago
I have created a schematic drawing with assorted components. After finishing, I realized I needed to add another parameter to all of the components. I have updated all of my component library files, but I can't figure out how to get the new parameter into all of the components already placed on the schematic. Is there a way to do this other than deleting them and replacing with a new component from the library? I recall somewhere while building the parts a check box that said something like "allow library synchronization" which was checked.
  • voltsandjolts
    0 voltsandjolts over 7 years ago
    In the library panel (with list of components) right-click on a component and select 'update schematic sheets'.
    I don't know of a way to update multiple/all components at once - you have to do them individually.
    In PCB Footprints there is an option to update all.
  • e14softwareuk
    0 e14softwareuk over 7 years ago in reply to voltsandjolts
    One important point to remember is that only open schematic documents are updated.
  • larry_137
    0 larry_137 over 7 years ago in reply to voltsandjolts
    When I right clip on the component in the Libraries window "Component Name" I only get: "Refresh Library" which does not update the schematic, "Place", "Select Columns", and "Edit".
  • voltsandjolts
    0 voltsandjolts over 7 years ago in reply to larry_137
    Sorry, I wasn't clear about which panel.
    I mean, in the SCHLIB editor, where you edit components. Right click on list of components there.
    So, you need your schematic (.SchDoc) and the library (.SchLib) to be open.
  • larry_137
    I am still not getting the option to update schematic sheets. I have *.SchDoc open in the editor. I have *.SCHLIB open in the editor and I see the schematic of my part. There is no list of components. Where is that? I have tried opening Schematic Component Properties and right click anywhere in that window does not do it. I have clicked the component in Projects (window), *.PrjPcb, Libraries, Schematic Library Documents, *.SCHLIB. I have clicked the component name in the Libraries window under Component Name. No luck. What am I missing?
  • e14softwareuk
    0 e14softwareuk over 7 years ago in reply to larry_137
    With the schematic library document open you can right click on the library list or use the toolbar icon. This will update the current symbol to all open schematic sheets.
