Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Derived Project
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 728 views
  • frontpage
Derived Project
larry_137
larry_137 over 7 years ago
I had a completed Circuit Studio design that I wanted to use as the basis for a new project. I used "Save As" to save the project in a new directory with a different project name. I then changed the names of the schematic and board design files to match the new project name. When I "Generate Outputs" all of the outputs have the new project name EXCEPT for the [project name].pdf under "directory"/outputs/default configuration which retains the old project name. It is easy enough to rename the file, but am I doing something wrong or is this a bug?
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    I would suggest avoiding Save As to create a new design independent of the original because it doesn't do what you think - it is only saving that specific file. To copy a project the easiest way is to use windows file manager to create a copy of the folder and use that copy as the basis of your new project.
