Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Show and hide nets/connections
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 6551 views
  • frontpage
zsoltg
zsoltg over 7 years ago
Does anyone know how to show hidden nets?
So what I did:
-hide all nets on placement by going to View->PCB ->Nets, select all, right click then Connections->Hide
-But when I want to enable all of them again only a few gets shows with View->PCB->Nets, select all, right click Connection->Show
Looks like the software is doggy.
I can see these hidden nets in the list view (still in PCB->Nets view) that their "Un-Routed (Manhattan)(mm)" length is "0".
the only way I found them bring back is to actually bring up the net property one-by-one (double click on the net list view) and simple press OK as the property on "hide Connection" is not ticked, once OK clicked it will show up.
Am I doing something wrong?
If not, then this is a bug, where can i report this?
thanks
Zsolt
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    Haven't seen this before and not something I can remember been reported. Is it the connection line that's gone missing or the tracking? I can take a look at your board to try and determine what's happening if you want to email a zipped copy of the PCB document to software@element14.com.
  • zsoltg
    0 zsoltg over 7 years ago in reply to e14softwareuk
    Hi, it is the connection line not showing up. There is no track as it is un-routed, but it is not a visible connection so you don't see it as "to be routed".
    Will send my board soon.
    Thanks for the help
    Zsolt
  • e14softwareuk
    0 e14softwareuk over 7 years ago in reply to zsoltg
    Thanks for sending through the PCB file, it does indeed display the symptoms where many of the connection lines don't show up. The secret seems to be Tools > Netlist > Clean All Nets to restore functionality.
  • zsoltg
    Thanks, does work!
