Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Foot Prints  missing from .lib file
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 962 views
  • frontpage
allycat
allycat over 7 years ago
Hi I was working on my footprints file when power went out on my computer.  When I rebooted project all foot prints are not showing up in library window.   The file size is still large.   Is there a way to recover this work.   It has a weeks worth of parts in it.
Regards
I was able to up date my components into PCB file but the foot prints are not visable in part manager.
CircuitStudioPCB.Lib.zip
  • tarribred61
    0 tarribred61 over 7 years ago
    The file size is only about 31KB so it is quite small.  I don't think there are any components in it.  Check your project history directories and maybe you might have something to recover.
    Good luck.
  • frog
    0 frog over 7 years ago
    I've inspected your library file using a hex editor - it contains all zeros, so I'm afraid there's nothing to recover.  I hope you can find a backup somewhere.
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    As mentioned by Thomas the <project-name>/History folder will hopefully contain a backup, these are ZIP files so hopefully you will find something to recover in there.
  • allycat
    0 allycat over 7 years ago
    Thanks I was not aware there was a history.   For some reason all of the PCB LIBs had the same problem.   The good news is I found a PCB file with the correct parts in it,.   It did take some work but I did repair the damage.
    Regards
