Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Copper pour does not tirm around traces but pours right over them.
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 509 views
  • frontpage
dreuter
dreuter over 7 years ago
I have a copper pour that I set up that initially follows the traces and pours around them. I closed the project and opened it a day later and adjusted one vertices and when pour  refills it pours over all the traces and does not avoid them anymore. What setting got changed that needs to be corrected.
  • dreuter
    0 dreuter over 7 years ago
    I found a link to a similar problem.
    Copper (polygon) pour problem
    Under design rules, somehow the clearance check was disabled. I have some 3D parts that are deliberately on top of each other which pop up as clearance issues. I must have some how in telling it to ignore the 3D object error turned off the over all clearance checking which ignored any traces when filling a polygon pour.
    I enabled the clearance check and now the polygon pour works correctly again avoiding the traces that are not part of its net.
