Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum I'm Missing Something
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 727 views
  • frontpage
tkjaktl
tkjaktl over 7 years ago
I can't seem to get interactive routing working.   When I look at properties for my pads, I see "no net" on all of them.  I've probably missed an important step like importing the netlist, etc.
I cannot manually assign a net to a pad, either.  Can someone help ?
  • tkjaktl
    tkjaktl over 7 years ago +1
    I should mention that I get a good net list in the EDIF file output.
  • adamwebber
    adamwebber over 7 years ago in reply to tkjaktl +1 suggested
    You're probably going to need to provide more information. Describe the steps you take to update the PCB from the schematics. Is this an existing board that recently worked properly and now has failed…
  • tkjaktl
    tkjaktl over 7 years ago in reply to adamwebber +1
    It's a new board, never worked before. Using version 1.5 . I resolved the compiler errors. Component Links all look ok. If I try to set connections to "show net" - it doesn't recognize any net names -…
  • tkjaktl
    0 tkjaktl over 7 years ago
  • adamwebber
    0 adamwebber over 7 years ago in reply to tkjaktl
    You're probably going to need to provide more information.  Describe the steps you take to update the PCB from the schematics.  Is this an existing board that recently worked properly and now has failed?  Which version of CS are you using?  Try compiling the schematic before you update the PCB.  What you're seeing is something I've never encountered so I probably won't be able to help much.
  • tkjaktl
    0 tkjaktl over 7 years ago in reply to adamwebber
    It's a new board, never worked before.   Using version 1.5 .  I resolved the compiler errors.  Component Links all look ok.  If I try to set connections to "show net" - it doesn't recognize any net names - even "GND" - I am using names from the output EDIF file.  If I try "show all" - I get no ratsnest.
  • tkjaktl
    0 tkjaktl over 7 years ago in reply to tkjaktl
    I'm making progress - I got a ratsnest now by executing "Update Schematics in ____PCB.PrjPcb"
