Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Can Circuit Studio do two boards in one project
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 834 views
  • frontpage
sclifford
sclifford over 6 years ago
I need to do a stacked board design can Circuit Studio do this?
Scott
  • tarribred61
    0 tarribred61 over 6 years ago
    I don't think this is the preferred method.  One project should be for one PCB.
    If you have a single PCB that you want to split into two PCBs you might get away with it by adding notes to a mechanical layer that tell the fabricator to score the PCB so it can be split in two.  There would be only the single PCB outline then for the combined boards.  I have never done this though and I understand some fabricators may still consider it as two separate PCBs.  Maybe someone else can comment?  Or go ahead and try it.  If you do split a single PCB it would of course have to have the exact same layer stackup, thickness, finish, etc..
  • clem57
    0 clem57 over 6 years ago
    Going through From Idea to Manufacture - Driving a PCB Design through CircuitStudio | Online Documentation for Altium Products , I see no way for what you want sclifford . A good suggestion first to start the main board setting core value and dimensions and then copy things to another project to get the same dimensions.
