Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Global replacement of footprint -  can it be done?
  • Locked Locked
  • Answers 2 answers
  • Subscribers 91 subscribers
  • Views 1119 views
  • frontpage
tkjaktl
tkjaktl over 6 years ago
I have a problem in a footprint which is used more than 100 instances on the board.   Problems are in soldermask and paste layers.  What are the ways I can shorten the required repair time?  Thanks.
  • adamwebber
    0 adamwebber over 6 years ago
    Go into your footprint .PcbLib editor and select the footprint that you have updated.  Under the 'Home' tab there is a button that says "Update PCB With Current Footprint".  Click that button.  You can also select the drop down menu but that will find any changes among ALL of your footprints and update everything.  This will update all OPEN instances of your footprint.
  • tkjaktl
    0 tkjaktl over 6 years ago in reply to adamwebber
    Thanks for your good answer.  I couldn't get this to work, I'm not sure what's meant by "open".  Anyhow, I hand-replaced all instances with corrected footprint.  Now, I have a lot of "collision error" to sort out.   If you have any idea why this happened, I'd love to hear it.
    Thanks again
  • mars01
    0 mars01 over 6 years ago in reply to tkjaktl
    What James meant was that all the PCB files open in the app tabs that use the updated footprint, will be updated and therefore will have the old footprint instances replaced by the new (modified) footprint. The collision error tells you that the modifications you made to the footprint altered the PCB such that the components are breaking the Component Clearance DRC rule (which means that some components are too close now with respect to that rule).
    This rule can be accessed by going to the PCB Rules and Constraints Editor (Design Rules) -> Component Clearance.
  • tkjaktl
    0 tkjaktl over 6 years ago in reply to mars01
    The problem seems to be that the new footprints have "no net" assigned to pins.  Is there an "ECN" which can take care of this?
  • tkjaktl
    0 tkjaktl over 6 years ago in reply to tkjaktl
    Found it...... thanks again to both of you.
