Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Validate Shows Some Footrprints Not Found
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 2094 views
  • footprint not found
stuartrumley
stuartrumley over 5 years ago
Starting my first board layout in CS and found this stumbling block.  Compiling the schematic shows no errors.  There are no errors in the compiled libraries.  I have added a CSPcbDoc.
I then run Update PCB Document and then Validate Changes.  Then I see in the Status column that there are a lot of errors associate with some components and not others.  For example, shown below, R1 is 1.00k RESC0402 as is R7.  Yet R7 has a Footprint Not Found RESC0402 message.  The Resistor library has been recently recompiled as has the project.
Any hints on how to clear this error message?
Thank you,
Stuart
  • tarribred61
    tarribred61 over 5 years ago +1 suggested
    Hi, Maybe verify that the search paths are included to the PCB footprint libraries.
  • tarribred61
    0 tarribred61 over 5 years ago
  • stuartrumley
    0 stuartrumley over 5 years ago in reply to tarribred61
    Hi Thomas,
    I think I found the problem. The Error message "Footprint Not Found" like many error message sometimes don't quite convey the full nature of the problem.
    In this case, I had built the 0402 package resistors with three Footprints; 1) Normal 0402 layout, 2) A an IPC standard layout with courtyard, and 3) A very trim layout used for RF and microwave microstrip. My intention being to delete only the desired footprint depending on application when capturing the schematic. Of course I had forgotten about the three footprints associated with each 0402 package and the CS compiler couldn't determine which to use, hence the error message.
    Stuart
