Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum CircuitStudio extensions
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1663 views
  • altium
  • cs
  • circuit studio
  • extensions
Puchacz
Puchacz over 4 years ago
Greetings,
I am looking for any informations about CircuitStudio's (1.5.2) extensions, that would help import/export projects between Altium and CS. In Altium there is a "Import Wizard", is there anything similiar in CS?
In my "extensions and updates" tab I cant see any possibble options to purchase or install. How can I do it?
  • tarribred61
    tarribred61 over 4 years ago
    There is no need to download extensions.  CircuitStudio import function is on the tool bar under the file command.  Then you need to choose the file type and it will show you what CAD it can import.  See screen capture below for the resulting browse window.
    You cannot directly import the PCB file from Altium Designer but you can export in the newer Altium Designer out to CircuitStudio.  I worked this way on a project a few months ago when we did PCB floorplanning in CS and then had someone else complete layout and routing in AD.  I was able to bring in the exported file and then complete the PCB.  This doesn't help if you are trying to import an existing AD PCB design (e.g. from a reference design).  But it does seem to provide a solution for working together.
  • tarribred61
    tarribred61 over 4 years ago in reply to tarribred61
    I should add that you can just open library files and schematic files from AD to CS and back.  I think the project files also work.  If you define PCB rules in AD, they may not function in CS because CS rules are very limited in functionality to just the basics.
