Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Gerber Files
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1772 views
  • gerber import
  • circuitstudio
  • gerber files
Gerber Files
Ozge
Ozge over 4 years ago
I am having an issue on circuit studio. After i create the gerber files, i am sending that to our PCB manufacturer. Sometimes they are making some changes and sending that files back to us for to be sure about if its ok to proceed manufacturing. But i can't open that files sometimes. Is that about version or anything else? I would be glad if you help me to understand the problem. Thank you.
  • jonasss
    0 jonasss over 4 years ago
    Hi Ozge,
    do you just need to view these files? I usually use Gerbv (Link) to look at the generated gerber files and to verify them. Sometimes I have trouble viewing drill data in Gerbv. I then use the free version of Viewmate.
  • Ozge
    0 Ozge over 4 years ago in reply to jonasss
    Yes, i just want to view them to be sure that if it is ready to manufacturing. I will check both of that programs. Thank you for your precious time.
  • tarribred61
    0 tarribred61 over 4 years ago
    Yes, as mentioned you need to use a Gerber viewer to look at the files.  There are a number of free ones.  However, unless they told you what was changed it may be very difficult to spot the differences from your originals.  Hopefully, they sent you screen shots and notes about what they changed.
    0 Jan Cumps over 4 years ago in reply to tarribred61
    Without promoting a manufacturer:
    Several of the online PCB manufacturers have an online renderer. These are usually good at taking Gerbers of many sources.
    You collect the fabrication files you got back from your manufacturer (Gerber and drill), and upload it to their portal while pretending to create an order.
    They will then render the different layers, with drill holes and mechanicals (clearances, ...). You don't have to complete the order to see the results.
    I used the customer portals of OSHPark and Seeed with success - just for viewing.
