Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Improperly assigned NETs
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1818 views
  • circuitstudio
  • pcb design
jgauthier
jgauthier over 4 years ago
Take a look at this MCPU in my schematic:
Please see pins 7, 12 which are not connected. Also look at pin 9, which is assigned to UART2_TX and pin 14 assigned to SPI1_MOSI.
When I import my changes to the PCB from the schematic I see my changes:
However, the PCB will not reflect the changes.
Not sure what to do with this.  I've restarted the application and opened/closed documents.  But at this point I can't proceed with the design.
    e14 Contributor over 4 years ago
    I'm just wondering if the problem is with the generated netlist or with the graphical PCB editor. Have you tried using any of the netlist tools, for example if you clean and then import the netlist? If you export the netlist is the listing correct?
  • jonasss
    jonasss over 4 years ago
    Hi! Did you double check the schematic- and footprint-library files of the component, are all pins assigned properly? And as alijaki stated I would also just try cleaning the netlist and updating the pcb again?
  • jgauthier
    I ended up removing the part and adding it back.  I have no idea how it got into this state of flux.
  • rami-6711
    rami-6711 over 4 years ago
    Go to schematic, open MCU properties. Reset "Unique ID" number.
    Go to PCB -> Menu Tools -> Component Links
    Use "Add Pairs Matched By >>" button.
    May be it will work.
