Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum How to add symbol to a new component libraly
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 909 views
karate_wo
karate_wo over 3 years ago
Hi.
I want to use this footprint -
https://www.snapeda.com/parts/SQMW5R47J/TE%20Connectivity/view-part/?ref=search&t=Through%20Hole%205watt%200.47ohm%20#download-modal - bud the symbol is missing.
And if i try take symbol from this - https://www.snapeda.com/parts/ERJ1GNJ393C/Panasonic/view-part/?ref=search&t=ohm - the Altium will crash: https://ibb.co/M6ZP8X5 / https://ibb.co/qnmsPqt
Any ideals?
  • tyro02
    tyro02 over 3 years ago in reply to e14 Contributor +1
    The Footprint Providing Service will create a footprint for you free of charge if you request the model of the part you want. Its footprint may be accurate, but it often differs from what we expected in…
  • tyro02
    In my case, I do not use libraries of unknown origin unless the footprint is quite complex.
    I will copy and paste the symbol from a preinstalled resistor symbol.
    e14 Contributor over 3 years ago
    Hi. They probably didn't supply a symbol because it's a basic component, and expected that the footprint would be added to an existing symbol such as the one in misc. devices. As for the crashing I have had something similar before, and I think it's a bug in CS. I had to copy the component, rename it, save and copile the lib.
  • tyro02
    The Footprint Providing Service will create a footprint for you free of charge if you request the model of the part you want. Its footprint may be accurate, but it often differs from what we expected in terms of symbols. The symbols that come with CircuitStudio are standard designs and are often used when busy.
    The only thing I don't like about these symbols is the resistors. The ready-made resistor symbol is horizontally wide, so connecting capacitors in parallel consumes unnecessary space in the schematic. Therefore, I reworked the resistor symbols myself as shown in the attached image.
    custom resistor symbol
