Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum my smd component things its a thru hole
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1197 views
ulao
ulao over 2 years ago
The below info is a test just to prove my issue, but in short the SMD thinks its a thru hole on the PCB.
Here I put it on the edge where there are no conflicts on the layer I put it on
here is the 3d view
I had to make my own sch library files but the foot print was available. I made my own sch and then added the foot print. But when adding to my PCB it conflicts on the under side layer. It looks likes pads are drawn on both side.
I see no way to draw pads on both layer in the editor how was that done?
  • ulao
    looks like the 3d image broke this was the image
    I also see thisimage
    can I just tell it top layer instead of multi ?
    dougw over 2 years ago in reply to ulao
    It sounds like you need to edit the footprint to remove the pads from the bottom layer.
    If the properties window you showed is global properties, you probably still want multilayer.
  • ulao
    ulao over 2 years ago in reply to dougw
    that was a property for a pad in the footprint. How do I do this for the entire footprint, or do I need to do each pad? So I just change to top solder?
    I don't know this CAD tool - my CAD software allows operating on a group at the same time.
  • GabeFromSpace
    GabeFromSpace over 2 years ago in reply to ulao
    You are correct. You can just set it to the top layer instead of multi. Top layer will also automatically include other layers such as the solder mask and paste mask.
