Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Search Vault "no results"
  • Locked Locked
  • Replies 16 replies
  • Subscribers 91 subscribers
  • Views 1698 views
  • search
  • vault
jaxxs
jaxxs over 10 years ago
Hello
I'm having trouble searching the vault.
I can see the list of manufactures but when I try to do a search I only get "Your search  "0805" gives no results. Try different keywords.
This occurs for any search criteria I try and search on knowing the part even exists?
Cheers,
  • harvie256
    harvie256 over 10 years ago in reply to pwenzel +1
    Hi Pete, As someone who has paid for it, and use it for my business daily I'm glad that e14 & Altium see a future for this product. I genuinely believe it is by far the best tool in the price range at…
  • harvie256
    On the left hand pane, you need to select the folder you want to search in, usually this means selecting the "Unified Components" folder.  With that selected, then do your search.
    e14 Contributor over 10 years ago in reply to harvie256
    I have the same problem.  Yes, I do select the unified components folder.  Frustrating.
  • e14softwareteam
    e14softwareteam over 10 years ago
    Sorry you are having a problem.  I am working with the developers to give you an answer as soon as possible.
    Tony
    e14 Contributor over 10 years ago in reply to e14softwareteam
    I have the same problem.  Also, just today, using the Vault makes CS crash.  I use CS without using the Vault...no crash.
  • e14softwareteam
    I received this message from the developers:
    "There seems to be an issue with our search servers. We are investigating."
    Tony
  • bhankiii
    bhankiii over 10 years ago
    Me too.  Some searches yield results, for instance 0603 will, but 0805 doesn't.  It's like the search engine is stuck looking at one column, instead of everything.  I guess I'll get nothing done today.
  • bhankiii
    bhankiii over 10 years ago in reply to e14 Contributor
    Same thing with me this AM.  Still can't search the vault, if I manually place a part from the vault CS crashes.  Just making placeholder schematic symbols for now so I can keep working.
  • e14softwareteam
    e14softwareteam over 10 years ago in reply to bhankiii
    Hi Hank,
    The developers are working on this.  Hope to get it resolved soon!
    Tony
  • e14softwareteam
    Per the developers:
    "This should be fully resolved now. Search will retrieve results and you will be able to click on and navigate into the results. We had to restore some previous back-end system changes to fully resolve this."
    We apologize for any inconvenience!
    Tony
  • bhankiii
    bhankiii over 10 years ago in reply to e14softwareteam
    Seems to be working for me.  But, I don't think I'll be using the vault much anymore.  I can't afford to be down for a week.  Making my own components takes longer, but at least I can find them and they don't crash the s/w.
