Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Variant Issues
  • Locked Locked
  • Replies 11 replies
  • Subscribers 90 subscribers
  • Views 3839 views
Variant Issues
adamwebber
adamwebber over 9 years ago
I am working with variants in CS.  I have declared the variant options to show the RED X on the schematics when parts are not fitted.  However, when I select the variant with not fitted parts, only the PCB is affected.  The schematics do not change.  How do I set it up so that it shows not fitted parts on both the schematic and PCB?  Rather, how do I display the RED X for not fitted components on the schematics?
My current steps:
1-Open Variant Manager
2-Add Variant
3-Name the Variant
4-Click OK
5-Select components "Not Fitted" in variant
6-Make sure that the variant options are selected in the schematic and PCB.
7-In Project Actions, select variant from drop-down menu.
8-Watch as the schematic does not change.
9-Watch as the PCB changes by making components disappear.
This is also the case when generating outputs.  I can only generate the No Variant output of the schematics.  The PCB works though.
  • harvie256
    harvie256 over 9 years ago in reply to e14softwareteam +1
    So the answer the question I asked... No Circuitstudio does not support multi-channel Variants like Altium Designer has for the last few generations. That's a shame, I use hierarchical multi-channel schematics…
  • vaidasmm
    vaidasmm over 9 years ago in reply to jamesharrimanaltium +1
    Thank You very much, now it works just fine .
  • orders@bmec.co
    orders@bmec.co over 6 years ago in reply to harvie256
    The BOM outputs seems to be correct. But model does not update.
