Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Integrated library compile crash
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 910 views
  • frontpage
fuubar67
fuubar67 over 9 years ago
I open a PCB project, during this time I attempt to edit a component in the IntLib, so I open the Integrated Library Project. I edit the schematic component, save it and run compile on the IntLib. During this time CS crashes. If I update the component in the open schematic (PCB project) and then compile, CS will finish.
  • e14softwareteam
    e14softwareteam over 9 years ago
    I will see if I can get an answer from the developers.
    Tony
  • e14softwareteam
    From the developers:
    I tried these steps and could not see a crash. Are they using CircuitStudio 1.3?
    It's possible something caused the software to become unstable before this operation. If they restart CircuitStudio and then try the same thing does it still crash?
    You may need to get a copy of the project and libraries if the crash is interfering with their work.
