Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Issue with Polygons
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 640 views
  • frontpage
Issue with Polygons
satyaeee247
satyaeee247 over 9 years ago
I am having trouble pouring polygon in Circuit studio
As I am drawing a polygon shape, the cursor is always going to the nearest centre of component PAD.
Is there any option to disable it?
Can anyone help me please.
Many thanks
Satya
  • adamwebber
    adamwebber over 9 years ago +1
    Right-click on your PCB. Select "Options -> Board Options" Uncheck "Snap To Object Hotspots" You will no longer snap to the center of component pads. You can also change your range. I often use 10 mil…
  • adamwebber
    You will no longer snap to the center of component pads.  You can also change your range.  I often use 10 mil snap grids so I set the hotspot snap to 8 mils.  Something smaller than what my snap grid is set to.
    The shortcut is SHIFT+E for object hotspot snap.  There are 3 settings and it cycles through all 3.
    To view the shortcuts, select the VIEW tab and then click "Shortcuts".
  • satyaeee247
    satyaeee247 over 9 years ago in reply to adamwebber
    Thanks James
    That worked
