Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum CircuitStudio - Unions
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1049 views
  • frontpage
  • altium circuitstudio
michael_n
michael_n over 9 years ago
I have a design from AD import to CS and there is an union with 5 components. My question is, how can i break an union or remove components from union? When i right-click on component -> Unions there are only 2 options: "Select all in Union" or "Deselect all in Union". Thanks!
  • michael_n
    michael_n over 9 years ago in reply to alexsander_altium +2
    Hmmm, that means i have to go back to AD, remove all unions and import the file with CS again. What are options availble if you do not have AD (anymore)? CS should remove the unions by importing or build…
  • e14softwareteam
    e14softwareteam over 9 years ago
    Checking with the developers.
  • alexsander_altium
    alexsander_altium over 9 years ago
    Hey michael_n, union functionality in CircuitStudio is not as robust as it is in Altium Designer. You would need to use Altium Designer for the added union functionality.
    -Alexsander from Altium
  • michael_n
    Hmmm, that means i have to go back to AD, remove all unions and import the file with CS again. What are options availble if you do not have AD (anymore)? CS should remove the unions by importing or build a function to break components from unions.
