Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum IPC Compliant Footprint Wizard
  • Locked Locked
  • Subscribers 91 subscribers
  • Views 2688 views
  • frontpage
k3vinwu25
k3vinwu25 over 9 years ago
Does circuitstudio have the IPC Compliant Footprint Wizard that Altium does? Can't seem to find it anywhere
Thank you!
  • hughesdw
    hughesdw over 9 years ago +5
    In my view the best way to achieve this (which is arguably better than AD's now slightly dated Valor IPC creation wizard) is to download Library_Expert_2017-15_Lite from https://www.pcblibraries.com/ In…
  • batuu
    batuu over 9 years ago
    Nope!
  • slowertech
    slowertech over 9 years ago
    No. But it would be great if they made that extension available for CircuitStudio.
  • hughesdw
    In Library Expet Lite:
    1. Create the footprint
    2. Click on the spanner icon to create the footprint.
    3. Set the following parameters (Obviously, the output directory is up to you)
    In CircuitStudio:
    1. Open a library project
    2. Select File -> Import
    3. Set the file type to: "PADS ASCII PCB Library (*.D)"
    4. Once the file is imported, Open the PCBLib library it's just created
    5. Click 3D Body
    6. Select "Generic 3D model"
    7. Click "Embed Generic 3D model"
    8. Select the file
    9. Click on the component origin to place the model
    10.Click Cancel on the 3D body dialog.
    11. press '3' to view the component in glorious 3D.
    Hope this helps
    David
    For reference, CircuitCtudio applies the following layer translations:
    Altium Designer (PADS) LayerCircuit Studio Layer
    0Top Overlay
    1Bottom Overlay
    2Mechanical 3
    3Mechanical 4
    4Mechanical 5
    5Assembly Text Top
    6Assembly Text Bottom
    7Assembly Top
    8Assembly Bottom
    9Mechanical 10
    10Dimensions Top
    11Dimensions Bottom
    123D Top
    133D Bottom
    14Courtyard Top
    15Courtyard Bottom
    16Mechanical 17
    17Mechanical 18
    18Test Points Top
    19Test Points Bottom
    20TopSolder
    21BottomPaste
    22Top Paste
    23Drill Drawing
    24Mechanical 21
    25TopOverlay
    26Courtyard Top
    27Bottom Solder
    28Bottom Overlay
    29Courtyard Bottom
    30Mechanical 22
    • Vote Up +5 Vote Down
