Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Circuit Studio doesn't answer when I created new PCB project on Windows 10 pro
  • Locked Locked
  • Replies 17 replies
  • Subscribers 89 subscribers
  • Views 3070 views
  • windows 10 pro
  • create new project
  • windows 10
datalight
datalight over 9 years ago
Hi All
I just bought Circuit Studio license and install program on my new laptop which has Windows 10 pro 64 bit. I downloaded Circuit Studio 1.4 version. 1.4 version workes fine on my old laptop which has Windows 7 pro 64 bit but it doesn't work properly on Windows 10 pro 64 bit version.
My problem is when I tried to make a new PCB project, Circuit Studio doesn't answer. I selected "Blank PCB Project" and click OK button then Circuit Studio doesn't answer. All templates results are same. I think it causes from Windows 10 permissions but I didn't found any document. Could you help me to solve this problem ?
  • e14softwareuk
    e14softwareuk over 9 years ago
    Hi, you mention v1.4 but there was a v1.4.1 release to address some Windows 10 issues amongst other things. Is it possible for you to upgrade and try using 1.4.1?
  • datalight
    datalight over 9 years ago in reply to e14softwareuk
    Sorry for wrong information, new computer has version 1.4.1 (Build 99). Old computer has version 1.4.0 (Build 84). Is there any comment for this problem ?
  • datalight
    I also downloaded version 1.4.0 (Build 84) now and tried with windows 10 pro, it has same error.
  • e14softwareuk
    e14softwareuk over 9 years ago in reply to datalight
    Thanks for confirming the software version. To help test if it is permissions can you run CircuitStudio as administrator. One option should be a right click to Run as Administrator on the program (DXP.EXE).
  • datalight
    Thank you for your time and attention. I already run the program as administrator mode but that is no change with normal mode. I tried to open old projects and it also couldn't open them but it can open schematics files.
  • e14softwareuk
    You say you can open schematics. What happens if you try to open an existing PCB document (CSPcbDoc) rather than opening a project?
  • datalight
    It could open and create seperately CSPcbDoc and SchDoc files but it couldn't create and open PrjPcb files.
  • e14softwareuk
    It is possible the project file has become corrupt. Create a new project and then copy in the existing documents and add to project, hopefully this will solve your problem.
  • datalight
    I can't create a new project. I also can't open created empty project files from another computer. Circuit Studio become corrupted on Windows 10 Pro when I try to open or create project file.
  • e14softwareuk
    If you think it could be related to permissions then create a new directory, something like C:\AltiumProjects, and then try creating a new project in that directory or copying an existing one from the old computer there.
