Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Circuit Studio doesn't answer when I created new PCB project on Windows 10 pro
  • Locked Locked
  • Replies 17 replies
  • Subscribers 89 subscribers
  • Views 3072 views
  • windows 10 pro
  • create new project
  • windows 10
datalight
datalight over 9 years ago
Hi All
I just bought Circuit Studio license and install program on my new laptop which has Windows 10 pro 64 bit. I downloaded Circuit Studio 1.4 version. 1.4 version workes fine on my old laptop which has Windows 7 pro 64 bit but it doesn't work properly on Windows 10 pro 64 bit version.
My problem is when I tried to make a new PCB project, Circuit Studio doesn't answer. I selected "Blank PCB Project" and click OK button then Circuit Studio doesn't answer. All templates results are same. I think it causes from Windows 10 permissions but I didn't found any document. Could you help me to solve this problem ?
  • datalight
    datalight over 9 years ago in reply to e14softwareuk
    I also tried them before and I tried again after your words but it doesn't work. When I try to create a new blank project, CircuitStudio creates "Blank PCB Project" and "History" folders than it can't create "Blank PCB Project.PrjPcb" file. As you know I can open and save CSPcbDoc and SchDoc files but I can't create and open PrjPcb files. I think problem is this but I didn't found solution yet.
  • datalight
    I'm also user of Circuit Maker and I downloaded it for make a test. When I create a project online and after creation click "Open Design" than Circuit Maker doesn't answer like Circuit Studio. Maybe it is meaningful for developers.
  • e14softwareuk
    e14softwareuk over 9 years ago in reply to datalight
    It is starting to appear that there is something 'wrong' with your system. Although there have been the odd reported crash on Windows 10, I do not know of anyone else suffering the problems you have. Is you installation of Win 10 non-standard in any way or not fully compatible with your hardware? Have you tried re-installing Win 10 and trying again?
  • tarribred61
    tarribred61 over 9 years ago in reply to datalight
    Just a suggestion here.  You say you cannot open a project created on another computer.
    Attached should be a zip of a blank PCB project I created.  There should be a blank schematic and blank PCB in it.  Hopefully, you can read these or at least you can get a clue about what is going on.
    FWIW, these were created on a Win10 pro based computer.
    Blank PCB Project.zip
  • datalight
    datalight over 9 years ago in reply to tarribred61
    Thank you for your reply. This also can't open.
    I found a error and I don't know why act like this. When I try to create a new PCB project or try to open old PCB project, Circuit Studio opens splwow64.exe printer service and I think don't take any answer and wait for answer from that service. If I close this service when CircuitStudio waiting, Circuit Studio create projects and open old projects but I can't use printer service. Mr. Peter Barnard said change default printer service and try. but it didn't work. I will delete printer driver and try again, I will let you know after try.
  • tarribred61
    Is your default printer on a network?  I don't know why CS would be trying to attach to a printer unless you attempt to print.  However, I usually set my default printer to a local PDF driver (e.g. Foxit).  Maybe trying something like that would help.
  • datalight
    Especially Canon release new driver and my problem was gone with new driver. It was very hard without printer image Thank you for helping.
