Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum CircuitStudio : Create a new footprint in an existing PCB lib
  • Locked Locked
  • Subscribers 91 subscribers
  • Views 2890 views
  • frontpage
pat180269
pat180269 over 9 years ago
I am new to CS so bear with.
I have created a project, schematics and a schlib and pcblib. When I open the pcblib I see the component I created and saved initially. If I want to create another footprint ( the second in this library ) how do I do it? There doesn't appear to be a menu item anywhere to add another.
The nearest I have seen is VIEW LIBRARIES, select component then right click and EDIT FOOTPRINT. But there is no option to create a new one.
  • adamwebber
    adamwebber over 9 years ago +1
    This is quite simple. Footprint: 1-Open the PCB Library tab 2-Right-Click on any component. 3-Select "New Blank Component" Schematic: 1-Open the SCH Library Tab 2-Click the "Add" button 3-Name the component…
  • adamwebber
    Footprint:
    Schematic:
    4-Click OK
    I hope this helped solve your problem.
  • pat180269
    pat180269 over 9 years ago in reply to adamwebber
    Thanks James, didn't see that button !
  • btremaine
    btremaine over 8 years ago in reply to adamwebber
    Hi ,
    In the instructions
    Footprint:
    Where is the PCB Library Tab? I'm able to use View--> Libraries and open a PCB library. When I right click there is no option to create a new part. This has stumped me for hours ....
  • adamwebber
    adamwebber over 8 years ago in reply to btremaine
    If you don't see the PCB Libraries Tab then it probably isn't shown on your workspace.  It took me a minute to figure this one out and for a while I thought that if I closed it, I'd never get it back.  But it's there.  In order to show it, take the following steps:
    1-Click on the "View" tab at the top next to the "Home" tab.
    2-Click on "Library".  This isn't to be confused with "Libraries".  Kind of confusing since it isn't in the same area as the rest of them.
    Happy National Medical Dosimetrist Day!
  • btremaine
    Thanks for your quick response,
    I'm close but no cigar image
    I don't see 'Library'? I do see 'PCB' with a drop-down menu but no Library there.
  • btremaine
    Okay!! I see now. I need to have the library editor open then 'Library' shows up as you show above.
    Brian
