Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Print settings not saved
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 241 views
  • frontpage
natthapol.vanasrivilai
natthapol.vanasrivilai over 9 years ago
I have problem with schematic print settings not saved.
I have defined variations for the design, and want to print out the schematic with physical component marked as "not fitted".
I went to the Outputs tab, and select the "Print" drop-down menu and select "Page Setup", then i click "Advanced" at the bottom of the dialog. Then i change the type of documents to "Physical Documents" and hit OK. When i return back to the same page again, the setting went back to "Logical Documents".
Please include this fix in the next update.
