ams OSRAM
  • ams OSRAM
ams OSRAM
Forum as7421 problem
Join ams OSRAM to participate - click to join for free!
  • Subscribers 25 subscribers
  • Views 1605 views
  • i2c
  • as7421
  • smbus
as7421 problem
fjj19990227
fjj19990227 over 2 years ago
I am trying to control the as7421 to read spectral data using python's smbus, but there is a problem that I can't change the value of LTF_EN on the enable bit 0x60, so I can't take spectral measurements, has anyone solved a similar problem, I'd appreciate it!
  • bidrohini
    bidrohini over 2 years ago +1 verified
    The problem may exist somewhere else other than the LTF_EN itself. I think it is better to verify the I2C address with an I2C scanner code.
  • primalfido
    primalfido over 2 years ago +1 verified
    PON must be enabled before LTF_EN can be enabled. Additionally there is a library here for Python that you can use which might be helpful: github.com/.../as7421
  • bidrohini
    +1 bidrohini over 2 years ago
  • fjj19990227
    0 fjj19990227 over 2 years ago in reply to bidrohini
    as your suggestion,i check the i2c address.besides 0x64(correct address),0x50-0x5F also exist at the same time. Weird.
  • primalfido
    +1 primalfido over 2 years ago
  • fjj19990227
    0 fjj19990227 over 2 years ago in reply to primalfido
    thanks it helps me a lot!
  • CorinnaR.
    0 CorinnaR. over 2 years ago
    thank you for showing interest in our products.
    Please use the following link for your question.
    Technical support | ams OSRAM (ams-osram.com)
    Best regards
