BitScope
  • BitScope
BitScope
Forum bitscope micro bs05
Join BitScope to participate - click to join for free!
  • Replies 19 replies
  • Answers 5 answers
  • Subscribers 39 subscribers
  • Views 4553 views
bitscope micro bs05
nvsabhiram
nvsabhiram over 6 years ago
I want to generate a single wave pulse with a certain frequency but not a continuous wave. is that possible? if yes how do I achieve it with bitscope micro Bs05?
  • fmilburn
    fmilburn over 6 years ago in reply to nvsabhiram +4 suggested
    What you have described above sounds like a repeating pulse - it has frequency. There is a user manual here - look in the Wavegen section. There also seems to be a lot of other on-line support .
    Jan Cumps over 6 years ago +3
    Doesn’t its generator have the one-shot setting?
  • fmilburn
    fmilburn over 6 years ago +2 suggested
    Hello Abhiram There are multiple ways to generate a single pulse. How it might be done is dependent on things you haven’t specified such as pulse duration, shape, voltage, accuracy, etc, etc. I am not…
    0 Jan Cumps over 6 years ago in reply to nvsabhiram
    What is the lowest frequency you can set?
    With the symmetry setting in its lowest, you can get a 1% duty cycle.
    If you can put frequency down to 1/(5*60) = 0.0033333, you’d have a pulse of 3 sec (5*60) * 1% every 5 minutes...
  • nvsabhiram
    0 nvsabhiram over 6 years ago in reply to Jan Cumps
    Thanks a lot. It was helpful.
    Also can we generate a pulse only when a trigger is given?? i.e. I want one pulse after 5 mins another pulse after 10 mins and so on.....
    And what if I want to 2pulses evey 5 mins?
    What is the minimum frequency you can set on the device?
  • nvsabhiram
    5hz
    Then a pulse every 5 minutes is out of its range.
  • nvsabhiram
    exactly.. so what do i do??
  • clem57
    0 clem57 over 6 years ago in reply to nvsabhiram
    Why must it be every 5 minutes? Maybe a look at this from another angle.
    0 shabaz over 6 years ago in reply to nvsabhiram
    On the list of possibly pointless tasks, this seems high unfortunately. Have you not questioned why it needs to be 5 minutes, or why you cannot use (say) an Arduino?
    There's an API for the Bitscope, you could try that.. but you may find it hard to find people with experience in that to do such a specific thing with it. An Arduino or Pi is 1000 times as popular.
    You should try to move the problem into something you actually have a chance to solve.
    0 Jan Cumps over 6 years ago in reply to shabaz
    shabaz  wrote:
    There's an API for the Bitscope, ...
    It seems to support the data acquisition side of the instrument only. As you suggested, looking elsewhere for a solution would be a better path.
