BitScope
  • BitScope
BitScope
Forum bitscope micro bs05
Join BitScope to participate - click to join for free!
  • Replies 19 replies
  • Answers 5 answers
  • Subscribers 39 subscribers
  • Views 4743 views
bitscope micro bs05
nvsabhiram
nvsabhiram over 6 years ago
I want to generate a single wave pulse with a certain frequency but not a continuous wave. is that possible? if yes how do I achieve it with bitscope micro Bs05?
  • fmilburn
    fmilburn over 6 years ago in reply to nvsabhiram +4 suggested
    What you have described above sounds like a repeating pulse - it has frequency. There is a user manual here - look in the Wavegen section. There also seems to be a lot of other on-line support .
    Jan Cumps over 6 years ago +3
    Doesn’t its generator have the one-shot setting?
  • fmilburn
    fmilburn over 6 years ago +2 suggested
    Hello Abhiram There are multiple ways to generate a single pulse. How it might be done is dependent on things you haven’t specified such as pulse duration, shape, voltage, accuracy, etc, etc. I am not…
  • fmilburn
    0 fmilburn over 6 years ago
    Hello Abhiram
    There are multiple ways to generate a single pulse.  How it might be done is dependent on things you haven’t specified such as pulse duration, shape, voltage, accuracy, etc, etc.   I am not familiar with the Bitscope but perhaps you could use it.  A single on / off pulse is easy with a microcontroller, any might work depending on duration, but an Arduino would easily be set up.  More information would be helpful - how is this to be used?  Does it have to be generated by a Bitscope?
    0 Jan Cumps over 6 years ago
  • nvsabhiram
    0 nvsabhiram over 6 years ago in reply to fmilburn
    I want a single pulse of frequency ranging between 200-500Hz, with voltage=5v, with a dutycycle  of 25% but using a bitscope only as I was asked to use bitscope only.
  • nvsabhiram
    0 nvsabhiram over 6 years ago in reply to Jan Cumps
    I could not find it. Please help me to find if it is there.
  • fmilburn
    0 fmilburn over 6 years ago in reply to nvsabhiram
    What you have described above sounds like a repeating pulse - it has frequency.  There is a user manual here - look in the Wavegen section.  There also seems to be a lot of other on-line support.
  • Fred27
    0 Fred27 over 6 years ago in reply to nvsabhiram
    How can a single pulse have a frequency? Do you mean a short burst of pulses at that frequency? Or do you mean a single pulse of a fixed width?
    0 Jan Cumps over 6 years ago in reply to Fred27
    It can. If it has a length (period), it has a frequency 1/period. Also for a single wave.
  • Fred27
    0 Fred27 over 6 years ago in reply to Jan Cumps
    I know what you mean, but I'm not sure I agree. A single pulse had a width but no period.
    For instance, take a 1us pulse. Is it 500kHz - assuming a 50% duty cycle? It could just as easily be 10kHz with a 1% duty cycle.
  • nvsabhiram
    0 nvsabhiram over 6 years ago in reply to Fred27
    yes. ignore the specified frequency too. I just want to generate just a single pulse first with any parameters. ( As the generated pulse is to be sent to one transducer @every 5 minutes #ignore ). So I need to generate a pulse using bitscope first and program to generate a single pulse every 5 minutes. How do I do that?
  • nvsabhiram
    Didn't help:(
