Cypress
  • Cypress
Cypress
Forum Query
Join Cypress to participate - click to join for free!
  • Replies 31 replies
  • Subscribers 10 subscribers
  • Views 5015 views
Query
I would like to know whether the ADC in Analog modules of the PSoC features "Simultaneous Sampling". Someone please provide some information on this ...
  • Sunnyzhuo
    0 Sunnyzhuo over 16 years ago
    the following link is base knowledge of the simultaneous samping:
    http://zone.ni.com/devzone/cda/tut/p/id/4105
    and the the following link is the simultaneous samping feature of the adc module in the cypress'psoc:
    DualADC_UM13555.pdf
    I hope they are useful to you
    0 e14 Contributor over 16 years ago in reply to Sunnyzhuo
    Thanks for the information. But we require 14 bit ADC for our application. Please suggest a correct part of PSoC and the development kit associated with it.
  • Oliver
    0 Oliver over 16 years ago in reply to e14 Contributor
    The PSoC 3 and PSoC 5 have 12bit and 20bit ADC block. Olny PSoC 1 has 14bit ADC block. So, what you require is PSoC 1 family. Farnell and Newark have many PSoC 1 parts and development kits. See the following;
    Recommendation PSoC 1 part  CY8C29666-24PVXICY8C29666-24PVXI
    CY8C29666-PVXI126719719M7238
    Recommandation PSoC 1 Dev Kit: CY3207ISSP
    CY3207ISSP147243019M6245
    You can access the following links if you want to select another parts and dev kits:
    PSoC 1 Development Kits link: In Farnell; In Newark.
    PSoC 1 Parts links:In Farnell; In Newark
    PSoC 1 Selection Guide.xlsPSoC 1 Selection Guide.xls
    0 e14 Contributor over 16 years ago in reply to Oliver
    Does this Part feature ADC with 4 channel simultaneous sampling? Also, does this feature USB interface module?
  • Oliver
    The CY8C24x94 serial PSoC (CY8C24894-24LFXI ) can support full speed USB(12Mbps, USB2.0 Compliant). and it features 6 Rail-to-Rail analog PSoC blocks which provide: 14bit ADCs, 9bit DACs, Programmable Gain Amplifiers, Filters and Comparators.
    Part stocked in Farnell, Part stocked in Newark (Order Code:1269153 and 19M7199)
    Development Kits
    in Farnell (1472435 , 1431701 , )
    in Newark (61M0500,41M1244, 41M1245 55M7153,41M1236,41M1272)
    Also, you can click the links for more Kits that you want to buy:
    Farnell Kits
    Newark Kits
    If you want to know more features of CY8C24894-24LTXICY8C24894-24LTXI, see the attached file.
    imageCY8C24094_CY8C24794_CY8C24894_CY8C249949.pdf
  • Oliver
    The CY8C24x94 serial can only support up to 2 channels simultaneous sampling AD converters(SAR, Delta Sigma and Incremental)
    The CY8C27x43 serial (CY8C271/2/4/5/643) can support up to 4 channels simultaneous sampling AD converters(SAR, Delta Sigma and Incremental)
    ,but it can not support USB feature.
    So, what you want to select?
    If CY8C27x43 serial (CY8C271/2/4/5/643) feature UART interface module, this will suit our requirement.
    If part CY8C24x94 serial provide 2 modules of 2 channel ADC also with the USB interface this will suit best for our requirement,
    Reply?
  • Oliver
    Sure, I know CY8C27x43, CY8C29x66, CY8C24x94 serials feature full-duplex Uart.
    Thanks a lot for the useful information.
    regards
    Manohar
  • Oliver
    You are welcome!
    Please contact Farnell or Newark local FSE or Sales, once you select the part and kit.
    Also, you can send the email to me (yzhang@premierfarnell.com) and I will forword your information to local Sale Engineer.
    best regards;
    oliver zhang
