Microchip
  • Microchip
Microchip
Forum Have a question? Ask our Microchip nanoWatt XLP expert!
Join Microchip to participate - click to join for free!
  • Replies 19 replies
  • Subscribers 31 subscribers
  • Views 3315 views
  • rishi_vasuki
  • low_power
  • security
  • microchip
  • xlp_mcus
  • smart_sensor
  • power_supplies
  • audio_expert
  • embedded
  • portable_music_player
  • extreme_low_power
  • motor_control
  • suny
nlarson
nlarson over 17 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Test & Measurement in the element14 Community Test & Measurement group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Rishi Vasuki
Rishi has been with Microchip Technology since 2001.  He has experience in developing portable music players and designing a wide variety of embedded applications (audio, security, motor control, power supplies and smart sensor).  His current focus includes PIC(R) XLP MCUs for eXtreme Low Power applications as well as Microchip's mTouch solutions using 8-bit PIC18 & 16-bit PIC24 MCUs.
  • Jorge_Garcia
    Jorge_Garcia over 16 years ago
    Hi Rishi,
    I wanted to know if you had any experience using MPLAB and the Pickit family of low cost programmers under Linux? Does Microchip have any plans to port MPLAB to Linux and Mac?
    I was considering going from Windows to Linux permanently and I just wanted to make sure I could still run MPLAB to program my Dspics. I'm currently running the latest version of Ubuntu 10.04 Lucid Lynx.
    Thanks for your time.
    Jorge Garcia
    Hi Rishi....
    I have a fishing boat that I can steer electronically:  if A is logic high, the boat turns slowly to port; if B is high, it turns to starboard; if both are the same (high or low) the pilot motor stops.  But I want to rig it as fully hands-off.  I am looking at an angular rate sensor gyroscope.  Isn't there some way that I can use it to provide the logic to hold the boat on a steady heading?  I have all the servo parts working fine.  Many thanks for your help, or, if I have attacked the wrong expert, can you shift this problem to another one....
    Bruce
    Dear Rishi,
    Im final year student and doing a project for button detection.
    I want to program PIC18F452 using mlab version 8.3.3 and CSS C- compiler.
    Actually Im beginner.
    What should I do?
    Could you teach me and give me a basic example to make sure that I already used the right software and compiler.Im really blurr about that.
    Thank you for your help.
    Hi Saara....
    I have Sure Electronics dual-axis magnetic sensor module with UART and I²C interface.  Can you recommend a µcontroller or processor to use with it to develop a magnetic compass project?
    Many thanks...
    Bruce Matthews
    831 484-9006
  • MicrochipRTCfr
    MicrochipRTCfr over 15 years ago in reply to e14 Contributor
    Hi Saara,
    PIC18F452 is an old PIC. you should better use PIC18F4520-E/PPIC18F4520-E/P which is pin to pin compatible and more recent.
    Regarding MPLAB, I recommend that you install the latest version v8.63 as your version is quite old...
    Regarding the compiler unless you alrady have CCS compiler you could use C18 compiler LITE version which is free.
    There are much more examples with C18 on internet ;=)
    regards
  • MicrochipRTCfr
    Hi Bruce,
    you can check this application note : AN996 with PIC18F2520.
    regards
    Hi Rishi,
         I am a student of the national program, Project Lead the Way. I am in the Engineering Design and Development section of the four years I have been in PLTW. We are trying to design and build an invention. We have encountered a roadblock that we hope you will be able to help us with. We have someone developing our program, but none of us have any knowledge of PCB assembly and what to use for our invention, can you please help us? Contact me at pltw.ldumont@actcstudents.org
    if you can.
    Best Regards,
    Logan DuMont
    I am trying to transmit and recieve block of few bytes through USART. I am using PIC18F452 and PIC18F252 at two kits. I am programming in assembly language. Tranmission is @1200 baud and Procesoor clock @4Mhz.
    My problem is,
    I cant recieve byte unless insert a delay at transmitter. But it slows the communication. What could be the solution ?
    concerned code is copied here. How to speedup the communication eliminating <<Delay1>> between consecutive bytes.
    TRANS
       bsf RCSTA,SPEN    ;Enable serial port
       bsf RCSTA,CREN    ;cont recieve mode
       bsf RCSTA,RX9    ;9'th bit recieve enable
       movlw 0x33
    ;for 1200 baud
       movwf SPBRG
       bcf TXSTA,BRGH    ;Lo spped baud select
       bsf TXSTA,TXEN    ;Transmit enable TXEN-1
       bsf TXSTA,TX9    ;9'th bit transmit enable
       movff CMD_T,TXREG    ;byte to transmit
       return
    TRAX
    TX_L
        bcf TXSTA,TX9D    ;CLR bit 9
        movff PWM_D,CMD_T
        call TRANS
        call Delay1
    TX_H
        bsf TXSTA,TX9D    ;set bit 9
        movff PWM_V,CMD_T
        call TRANS
        return
    Delay1
        movlw    H'FF'
        movwf   Dx
    L2
        movwf     Dy
        clrwdt
    L1    decfsz    Dy
        goto    L1
        decfsz  Dx
        goto    L2
        return
    ;;;; recieve iterrupt service routine is .....
    ISR_RX
        btfss RCSTA,RX9D
        goto LB
        goto HB
    HB     movff RCREG,FDBK_H
        goto OVER_RCV
    LB    movff RCREG,FDBK_L
    OVER_RCV
        retfie
    Hiya , this sort of question is best answered by our team of engineers at :
    www.microchip.com/support
    Best Regards , Mike
    Mike McGlade  -  Senior Regional Channel Manager - Catalogue
    mobile tel: 07713 175760
    Skype: mikemcglade
      http://www.microchip.com/infodepot
