Moto Mods
  • Moto Mods
Moto Mods
Forum Help with the developer problem(Developer Tools: Build from Source)
Join Moto Mods to participate - click to join for free!
  • Answers 2 answers
  • Subscribers 57 subscribers
  • Views 776 views
  • developer tools: build from source
erisonkwok
erisonkwok over 9 years ago
Hey guys.
My Ubuntu(ubuntu-14.04.5-desktop-amd64) systerm run within a virtual machine.
I am doing what https://developer.motorola.com/build/tools/setup-environment tell me to do.Here seems nothing wrong.
Next step https://developer.motorola.com/build/tools/build-from-source ,there is one error.
$ export PATH=$PATH:$BUILD_TOP/manifesto:$BUILD_TOP/bootrom-tools                (this step run correctly)
$ cd $BUILD_TOP/nuttx/nuttx                                                      (this step run correctly)
$ make distclean        (this step run correctly)
$ cd $BUILD_TOP/nuttx/nuttx/tools                                                (this step run correctly)
$ ./configure.sh hdk/muc/base_unpowered                                          (this step run correctly)
$ make        (this step goes wrong)
The results are as follows,
Missing path to the output file
USAGE: tools/version.sh [-d|-h] [-b <build>] -v <major.minor> <outfile-path>
Try 'tools/version.sh -h' for more information
chmod: cannot access ‘.version’: No such file or directory
make: *** [/home/xcjapp/Build_Environment/nuttx/nuttx/.version] Error 1
So,how can I fix it?
Thank you very much.
  • leo.andrade
    leo.andrade over 9 years ago +1 suggested
    Hi Erison. I am also using a VM and I did not face this issue. By checking the logs, in my case, the version.sh is being called with the following parameters: tools/version.sh -v 0.1 -b bdf298a .version…
  • leo.andrade
    leo.andrade over 9 years ago in reply to erisonkwok +1 suggested
    Erison, Strange! The nuttx directory should be retrieved from a git repository created by the command " git clone https://github.com/MotorolaMobilityLLC/nuttx " that you had executed during the "Download…
  • erisonkwok
    erisonkwok over 9 years ago in reply to leo.andrade +1
    Hi Leo, Thank you very much. The error is gone. Doing what you suggest,step by step,everything goes well,and did not face that issue again.Maybe the last time I clone the nuttx folder missing some documents…
  • leo.andrade
    0 leo.andrade over 9 years ago
    Hi Erison.
    However, I noticed that If I remove the parameter for the -b, I have the same error than you:
    $ tools/version.sh -v 0.1 -b .version
    So, it seems that the build parameter is missing when it is called by the make because the OVERRIDE_BUILD_NUM (in Makefile.unix) is empty.
    Can you check what the "git describe --always --dirty --match nothing" command in $BUILD_TOP/nuttx/nuttx folder is returning for you? It should be an hexa value.
    Leo
  • erisonkwok
    0 erisonkwok over 9 years ago in reply to leo.andrade
    Hi Leo.
    First of the all,thanks for your time.
    Check the command what you tell me,it seems return somthing different.The result are as follow,
    xcjapp@xcj-virtual-machine:~/Build_Environment/nuttx/nuttx$ git describe --always --dirty --match nothing
    fatal: Not a git repository (or any of the parent directories): .git
    Thanks again!
    Erison.
  • leo.andrade
    0 leo.andrade over 9 years ago in reply to erisonkwok
    Erison,
    Strange! The nuttx directory should be retrieved from a git repository created by the command "git clone https://github.com/MotorolaMobilityLLC/nuttx" that you had executed during the "Download Source Code" section.  Do you remember to move the dir or perform any other operation in this dir?
    My suggestion, if you do not have anything to loose (your code and changes), remove the nuttx and get the git repo again:
    cd $BUILD_TOP
    rm -Rf nuttx
    After that, follow the steps in your first post.
    Leo
  • erisonkwok
    Hi Leo,
    Thank you very much.The error is gone.
    Doing what you suggest,step by step,everything goes well,and did not face that issue again.Maybe the last time I clone the nuttx folder missing some documents.
    Erison
