Moto Mods
  • Moto Mods
Moto Mods
Forum MDK Issues - Unable to test examples
Join Moto Mods to participate - click to join for free!
  • Subscribers 57 subscribers
  • Views 1130 views
twhalen08
twhalen08 over 9 years ago
Hey all,
Ive been testing out some of the examples. Initially everything was fine. I got each to run once. After that, no matter what i do and no matter which personality card I use, I get an error when it tries to update the firmware. My buddy is having the same issue. Anyone else experience this? How did you overcome it? Thanks.
  • twhalen08
    twhalen08 over 9 years ago +1
    Clear application data for the Moto mods manager service and reattach. That solved it for jlavigne08 and I. I do have a bad audio card tho
  • anttibrain
    anttibrain over 9 years ago
    No, all works here, can switch between personality cards, all work, firmware is updated and started as needed.
    Did you flash anything that you compiled yourself? Maybe you managed to destroy the bootloader?
    EDITED:
    After Android update NOTHING works! All functionality is completly broken, nothing can be done at all. It all worked, then MOTO-z wanted to perform update, and after update the moto mods no longer work. The Display personality card, is recognized as "projector" any other mods also not working. So every thing got broken by the phone update.
    image Really sad, what todo now? By new phone and disable Android update? Really? That is not a solution for long term.
  • twhalen08
    I do have a bad audio card tho image
  • flowflow25
    flowflow25 over 9 years ago in reply to twhalen08
    Thomas, how did your audio card go bad?
    Antti, please check the Play store for the latest Mod Manager.  Sadly, erasing the apps data is the current workaround while we resolve this.
  • anttibrain
    anttibrain over 9 years ago in reply to flowflow25
    apps data delete was the fix, everything was uptodate already
  • twhalen08
    twhalen08 over 9 years ago in reply to flowflow25
    Hi Christian. All of the other personality cards that i received seem to work just fine when the dips are set  correctly. All except for the audio card. The audio card will just come up as blinky.
  • flowflow25
    You're experiencing the firmware download issue, we're working on that.  The "good news" is that it only applies to the MDK, not any commercial Mods.  Erasing the Moto Mods Manager's app data should get you going again.
    Of course, you could also build the audio firmware and flash it directly with either the MDK Utility or openocd.
    Another note is to make sure the card is seated properly, it almost sounds like the bootloader can't read the EEPROM in the Personality Card the defines the PID.  If it continues to come up Blinky (MDK Utility shows Blinky, not simply "Firmware") we may need to take some steps to program the EEPROM (it isn't terrible).
