Moto Mods
  • Moto Mods
Moto Mods
Forum Help!problem of Developer Tools: Starting a New Project
Join Moto Mods to participate - click to join for free!
  • Subscribers 59 subscribers
  • Views 1009 views
erisonkwok
erisonkwok over 9 years ago
Hey guys.
There was something wrong with my project.
At the "selecting your protocols" step,I copy the 'hdk-temperature.mnfs' file and rename it as 'hdk-ProjectUART'.
At the "Creating the Basic Project Files" step,I copy the 'base_powered' floder and rename is sa 'ProjectUART'.
$ cd $BUILD_TOP/nuttx/nuttx                         (ok)
$ make distclean                                    (ok)
$ cd $BUILD_TOP/nuttx/nuttx/tools                   (ok)
$ ./configure.sh hdk/muc/ProjectUART                (ok)
$ make                                              (2 errors)
The error as follows,
manifest.c:76:24: fatal error: manifest.inc: No such file or directory
#include "manifest.inc"
compilation terminated.
make[2]: *** [manifest.o] Error 1
make[1]: *** [greybus-utils_all] Error 2
make: *** [../apps/libapps.a] Error 2
Erison
  • lgamini
    lgamini over 9 years ago
    Hi Erison,
    If you want to change your manifest file as hdk-ProjectUART.mnfs, then you must update  it in your ProjectUART/defconfig file.
    Try changing the below lines in your defconfig file, and do a clean build.
    #CONFIG_MANIFEST="hdk-powered"
    CONFIG_MANIFEST="hdk-ProjectUART"
  • erisonkwok
    erisonkwok over 9 years ago in reply to lgamini
    Hi g lucky,
    Thank you for your suggestion.I think I know how to fix it.
    Erison
  • vpr_motomods
    vpr_motomods over 7 years ago
    Have same issue. Using linux.
    Last few lines where make stops
    CC:  mods.c
    CC:  wdog.c
    AR:  mods.o wdog.o
    CC:  readline_common.c
    CC:  readline.c
    AR:   readline_common.o readline.o
    CC:  sysinfo.c
    AR:    sysinfo.o
    CC:  manifest.c
    Makefile:136: recipe for target 'manifest.o' failed
    Makefile:155: recipe for target 'greybus-utils_all' failed
    LibTargets.mk:157: recipe for target '../apps/libapps.a' failed
