Moto Mods
  • Moto Mods
Moto Mods
Forum Problem of Developer Tools: Flashing Firmware
Join Moto Mods to participate - click to join for free!
  • Subscribers 58 subscribers
  • Views 702 views
erisonkwok
erisonkwok over 9 years ago
Hey guys,
I am creat a new project as the document of "Examples: Sensor Personality Card(https://developer.motorola.com/build/examples/sensor )" say,but failed in flashing part.
xcjapp@xcj-virtual-machine:~/Build_Environment/muc-loader$ openocd -f board/moto_mdk_muc_reset.cfg -c "program ./out/boot_hdk.bin 0x08000000 reset exit"
Open On-Chip Debugger 0.10.0-dev-00346-gd3d86cc (2017-04-13-23:48)
Licensed under GNU GPL v2
For bug reports, read
  http://openocd.org/doc/doxygen/bugs.html
Info : FTDI SWD mode enabled
srst_only separate srst_nogate srst_push_pull connect_deassert_srst
adapter speed: 500 kHz
adapter_nsrst_delay: 100
cortex_m reset_config sysresetreq
Info : clock speed 500 kHz
in procedure 'program'
in procedure 'init' called at file "embedded:startup.tcl", line 473
in procedure 'ocd_bouncer'
** OpenOCD init failed **
shutdown command invoked
xcjapp@xcj-virtual-machine:~/Build_Environment/nuttx/nuttx$ openocd -f board/moto_mdk_muc_reset.cfg -c "program nuttx.tftf 0x08008000 reset exit"
Why the OpenOCD init failed?
  • garengllc
    garengllc over 9 years ago +2
    Did you try it with DIP switch B4 set to the ON position?
  • garengllc
  • erisonkwok
    erisonkwok over 9 years ago in reply to garengllc
    Hi Jason,
    Thank you very much.You are right,I forgot the DIP switch.
    Erison
