Moto Mods
  • Moto Mods
Moto Mods
Forum Increase size of RAMLOG
Join Moto Mods to participate - click to join for free!
  • Subscribers 57 subscribers
  • Views 608 views
mdastec
mdastec over 9 years ago
Hi.
I am trying increase the size of my RAMLOG.
In my ./nuttx/nuttx/.config
# System Logging
CONFIG_RAMLOG=y
CONFIG_RAMLOG_SYSLOG=y
CONFIG_RAMLOG_LAST_DMESG=y
# CONFIG_RAMLOG_CONSOLE is not set
CONFIG_RAMLOG_BUFSIZE=3056
# CONFIG_RAMLOG_CRLF is not set
CONFIG_RAMLOG_NONBLOCKING=y
CONFIG_RAMLOG_TRULY_CIRCULAR=y
If I change CONFIG_RAMLOG_BUFSIZE to something greater than what the defconfig had (2032)  I get a compile error:
LD: nuttx
arm-none-eabi-ld: warning: /usr/lib/gcc/arm-none-eabi/4.9.3/armv7e-m/libgcc.a(bpabi.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
arm-none-eabi-ld: warning: /usr/lib/gcc/arm-none-eabi/4.9.3/armv7e-m/libgcc.a(_divdi3.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
arm-none-eabi-ld: warning: /usr/lib/gcc/arm-none-eabi/4.9.3/armv7e-m/libgcc.a(_udivdi3.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
arm-none-eabi-ld: /home/mike/motoModFirmwareBuild/nuttx/nuttx/nuttx section `.ramlog' will not fit in region `sramlog'
arm-none-eabi-ld: region `sramlog' overflowed by 2048 bytes
Makefile:205: recipe for target 'nuttx' failed
Does anyone know how I can create a larger circular buffer for dmesg?
Mike
  • mdastec
    Also - I tried logging to the console using the following:
    # System Logging
    CONFIG_RAMLOG=y
    # CONFIG_RAMLOG_SYSLOG=y
    CONFIG_RAMLOG_CONSOLE=y
    CONFIG_RAMLOG_BUFSIZE=2032
    I tried with CONFIG_RAMLOG_SYSLOG=y but nothing came out the nsh>
    The above give a compile error.
    Any advice on proper way to config to get debug to the console in stead of or in addition to the ramlog?
